jack up on axle stands
removes wheels
13mm & 15mm spanner and remove caliper pivot bolts
lift up caliper
pads sit in staniless steel anti-rattle clips
should just lift out
caliper piston is r/h thread both sides
so you can either use a wind-back tool or use a screw driver or pliers
to wind the piston back - must use pressure to push it back
clean all fittings
copperslip pad/caliper mouting points
re-fit all
press brake pedal hard 5-times
work handbrake on/off 3-4 times to settle pads and adjust piston to pads
check for correct operation
re-fit wheels etc
:thumbup1:
