probs
hey guys what can make the inside pad on the front right wheel to wear all the way to the steel . but alll the other pads are still 30% wear.
has anyone had this prob.
any help would be great
most likely a sticking/jamming caliper piston - keeping constant pressure on the pad and hence it wearing out
get the pads out and see if the pistons are free - push them back and see if they pump out - do this several times to make sure
it could also be corrosion causing the pad to stick and not retract the fraction they do when you release the pedal pressure
Gary pa28 Engine, Gearbox, Exhaust and Air Intake 14
