Hi everyone, my 197 recently has started making the noise when i rev it fully in second gear and when i shift it into 3rd, it makes the noise like i havent pressed clutch fully, and u can hear the crunching in the gears. I have changed the top mount of the engine, since its been fu.. up.
The same noice is happening in the 3rd gear when i am braking and shifting down from 4th to 3rd, is it possible that something else can it be, or should i try to change all my engine mounts, cause i think that engine moves a lot but it doesnt make any noise.
Other than that, the gear changes are completely fine on normal revs...
The car has only 30.000km on it..
What else can it be if not the engine mounts.
Thanks!
Thanks!
