Noise coming from the headlamp when the lights on
197JST
Gold Member
Good evening all,
Ive noticed a noise coming from the headlamp but only when I put the main lights on which seems a bit odd to me, is there anything I can attempt to adjust as it sounds like an electrical whining.
fingers crossed in support, thank you :smile:
Do you have LED bulbs? As some have fans on them to cool them, so they make a noise.
It’s the standard lights that are fitted, I’ve only noticed it tonight, but I recently had the headlamp height adjusted. Not sure if this has now caused issues with the adjuster motor?
Reactions: suj
What would your root of action to take be, fit a new motor to the headlamp?
