No power
Joshluff
Hello :smile:
So over the past week my car had decided to play up. It was not pulling away not starting and just generally being a pain
The first issue was a snapped MAP sensor. Replaced that all problems were solved
Now the new problem is. When ever I try to give it a boot it judders, I can take it up the revs slowly but not fast
Does any one no what it could be
It's like the car can't process it fast enuf
Cheers everyone :smile:
Engine mounts? I found my Clio very juddery when I first picked it up, replacing the upper torque arm with the poweflex parts seemed to help loads. I've since done the lower engine mount too
If I build the revs slowly it's fine It's only when I put my foot down At around 3-4k revs it just won't go
Did you buy a genuine Renault map sensor or a cheap eBay special? The genuine one is around £70 iirc and it is a case of you really do get what you pay for! - Read reports of quite a few people going for the cheaper ones on eBay and having running issues.
Thats a great shout tbh! Would like to know this!
Genuine from renault. I believe it was a cheap one on there ( the one that snapped )
