Had the car a couple of weeks and done enough miles to get comfortable with it. No major problems but would like to know if my transmission issues are normal or not.
1. Difficult to select gear when cold. This is only just after starting the car when stone cold. Try to select 1st or reverse and it won't slot home. Needs patience and selection of other gears before 1st/rev will engage.
Once selected, the clutch bite point is mid-way up the pedal so I don't think it's clutch relayed. I have also bled the clutch slave but no improvement. Once moving, selecting other gears is no problem. If the car has a little heat in it then no problem on restarting.
2. Clutch pedal vibration. This is related to engine speed. Resting my foot gently on the clutch pedal at motorway speeds I can feel a vibration as if the pressure plate is out of balance.
Any info or advice on these issues would be much appreciated!
Sent from my LG-H815 using Tapatalk
