New Brakes Suggestions
Discussion in 'Suspension, Brakes & Steering' started by mattb03, Feb 26, 2019.
  1. mattb03
    mattb03 Paid Member
    36
    Car:
    clio 172
    After some brake advice, first track day at Snetterton last week in my new Meglio and the brakes were fading and juddering after less than ten minutes, the pads are decent Ferodo ds 1.11 (front) and DS2500 or the rear.
    Not sure on the make of the discs and they don’t look great so going you change them first, before I order the popular Brembo HC any other suggestions.
    Also, I would like to run some cooling ducts for the brakes, has anybody done this already, any info would be great.
    Matt
  2. J90RDN
    J90RDN Paid Member
    302
    Leicestershire
    Car:
    Clio 197 - Track
    A vote here for Brembo HC solid discs. Seen too many issues with drilled, slotted discs to deviate. I run PFC front pads, and with the HC discs the stopping power is immense, and doesn't fade all day when on track. Have the cheapest pads I can find for the back as the back brakes do F all on these cars.
    I'd say change the discs for HC, change the fluid if you don't know it's history (perhaps splash out on some DOT5.1 as it's not much more expensive than 4.1), and as long as you're confident the ds pads are OK I'd say give it another try and see if there is an improvement.
  3. Mark_L
    Mark_L Platinum Member
    514
    Car:
    197 Cup
    If you look in the for sale section there is a wanted ad for brake ducts.
    @trackspec197 is doing a group buy on the ducts so get your name on the list.
    Also if you don't know how old your brake fluid is get some decent hi temp fluid in there as it will help massively.
  4. Big Ben
    5,617
    Herts
    Car:
    197
    I run brembo hc discs with ds1.11 front
    Renault Oe discs with ds2500 rear
    Motul rbf600 fluid.
    No issues with fade or judder. Admittedly I’m not the harshest on brakes but that setup should be fine
    Mark_L likes this.
  5. mattb03
    mattb03 Paid Member
    36
    Car:
    clio 172
    cheers for the reply guys, brembo it is.
    @Mark_L how much are the ducts going for
    Mark_L likes this.
  6. GazMav
    GazMav Paid Member
    62
    Car:
    Daily 197, Track Meglio
    I've got exactly the same setup on my meglio and booked onto oulton next month.
    Last owner said his brake fluid boiled due to the turbo being so close to the brake fluid res. He upgraded to 5.1 racing fluid and said it was fine after.
  7. Mark_L
    514
    Car:
    197 Cup
    £65 posted I think.
  8. Big Ben
    5,617
    Herts
    Car:
    197
    I thought 5.1 was frowned upon for some reason on these renaults?
    Might be wrong
  9. 197trackpotato
    197trackpotato Paid Member
    20
    Car:
    Clio 197
    Meglio here
    I'm running
    Brembo hc plain discs on front
    Dsuno pads
    Castrol srf fluid
    Braided lines
    Genuine Renault on rear due to having built in bearing
    Ds2500 pads
    Braided lines
    First day will be 9th April at Donny
    Sent from my Pixel 2 XL using Tapatalk
    peter, mattb03 and Big Ben like this.
  10. Big Ben
    5,617
    Herts
    Car:
    197
    Let us know how you find the Uno’s Please. Might be my next purchase once DS1.11’s run out
  11. peter
    peter POTM Winner - February 2017 Gold Member
    1,313
    lalaland
    Car:
    RB7 #166
    +1
  • Share This Page
