New ABS pump calibration
bedoef
Hi guys,
I thought I would check here. I have a Mk3 Clio RS '12, and recently had an ABS pump failure. I have purchased a replacement with the same part number, but the pump needs to be initialized and calibrated. I only have an RS Tuner to work with for now.
Can I buy the ABS module from Fastchip to sort this out through my RSTuner? Does anyone have the calibration settings for the ABS?
Well your ABS failure could be three things the mechanical block the control circuit board or the loom that connects it. Now if you feel OK about it and the part numbers are a full match swap the ABS circuit board over then it does not need programed.
It appears to be the mechanical part - seems air got into the system and started locking up a wheel.
Interesting shout, I will have a look, thanks!
