need help.
picture.php
went to change a busted bulb on the rear number plate, little did i know its not a standard bulb, anyone know where i can get and LED light to fit?
That LED bulb is a "canbus" led, but tbh it doesnt need to be.
no led's In a 197(cant comment on 200)need to be canbus.
Canbus LED's are designed to stop error codes or like my focus the normal led don't go out completely even when turned off which is what happens with a normal led.
Search eBay for "canbus 501 led"
That looks like the right bulb same as i used i think . r u sure it does ot fit mine was a tight fit
replaced them with bulbs and the bulbs has blew a fuse, but chunky fuse under the bonnet. Renault in the morning :/
Easy fix mate, it's underneath a couple things right next to the battery, took me about 5 mins to access it and it was a normal fuse that you can buy from petrol station.
The bulbs are LED as I changed them all, there's no need for them to be though - personal choice that's all.
No idea why it would blow a fuse though.
