Hi All,
Any help would be greatly appreciated...
I've got today and tomorrow off work because I was planning to rectify a couple of MOT advisories on my 197. I've got one tyre that's near legal limit and 'play in steering rack inner joints'. I was planning to fit the new tie rods and TRE's today, then pop down to the garage for the alignment and to have the new set of tyres fitted (they are all different makes etc, so I thought a set would be better) tomorrow.
Got everything ready, but was just going to head into town to get some degreaser and some gloves. 5 minutes into my trip and the engine warning light starts to flash, the ESP light is on, as well as the traction control light and the maintenance spanner. The car seemed to be OK but I was only driving quite slowly and couldn't tell if it went into 'limp mode'.
Anyway, I pull over and turn everything off and have a quick google on my phone, and decided to fire it back up again to drive home. All the lights had cleared and it seemed to be driving OK. I got home plugged in my OBDII scanner and got quite a significant list of error codes:-
My question is, has anybody experienced any of these, and if so what was the resolution?
Also, should I clear the codes and see what appears again?
Any help/advise would be greatly appreciated.
Thanks,
Tom.
Error Code | Description | Comments |
P0300 | Random/Multiple Cylinder Misfire detected | Quick search on here says possibly Lambda, but could be anything? |
P0503 | Vehicle Speed Sensor Intermittent/Erratic/High | Not Sure, dodgy speed sensor? |
C1203 | ABS Outlet Valve Coil Rear Circuit Open | Not Sure |
U1F03 | None | Google showed nothing |
U1B03 | None | Google showed nothing |
U03DB | None | Google showed nothing |
Thanks,
Tom.
