My car just failed its MOT on emissions. The results were pretty much the same across the fast idle tests and the natural idle test:-
CO% - 10.410
HC - 940ppm
Lambda - 0.694
I've checked the fault codes and had p0300. I checked and changed the spark plugs and you can see the car has been rich for a while. On start up you can smell the unburnt fuel.
My Idle sometimes dips down below about 600 rpm when the car is warming up.
I don't really know where to start with this, obviously my emissions are miles off. I left the car with the MOT station and it quite clearly says on the results "Engine oil temperature measurement was by-passed . ( Temp Gauge checked)" is it possible they tested it cold? would cold test results be that far out?
Any ideas where to start?
			CO% - 10.410
HC - 940ppm
Lambda - 0.694
