Heppy997
			right lads looking for a bit of advice off anyone who has replaced the lower ball joint on a 197/200 themselves. Attempted it today but it's bloody slow as the cars 10 year old and don't thing the suspension has ever been touched, so naturally I've ended up having to cut or drill most bolts out.
Anyway I'm just trying to figure out what needs to come off/bolts to undo to get access to the joint. Also, do you press it out the hub in situ or is it best to remove the whole hub?
Ali
Ali
