Kam Racing Wheel Spacers
Not used them but done forget you’ll need longer bolts or a stud kit also
I’d consider the stub axle spacers for the rear, also don’t forget this alters all the steering geometry at the front so it will reduce handling capability’s regardless of what the blurb in there advert says, especially on the front, basically you push the wheels outside of the virtual centres of the steering axis and so when you brake over bumps the wheel wants to turn to the right if the right has more grip etc, same with acceleration, torque steer will also be increased!
Choose one, looks or handling, if you want to fill the arches, get wider wheels with adjusted offset so the steering axis geometry remains the same
A Clio General Chat 2
U Spotted 5
SeanTheSheep Clio General Chat 0
Matty_L Clio General Chat 0
Fernandez Spotted 0
