Pop the bonnet, 2 bolts either side of the bonnet catch, a plastic flat head screwdriver clip next 2 each headlight. Then under the car theres 2 bolts securin the bumper undertray 2 the subframe. Then remove the front inner wheel archs which are secure by a few big plastic clips a two screws underneath securing 2 the undertray. Once removed theres a bolt betweem the bumper and arch near 2 the lip, them the bumper sides wil pul out from the wing (give a gud pul as them clipped into the wing.) them the whole front bumper wil just pull up and off. Then just undo the fog lights (theres a main plug on the passager side 4 both) and a drain pipe that just clips into the bumper same location as the fog plug.  while off u might aswel remove the box that restricts airflow 2 the plastic induction infront of the engine. Did this wit mine. Hope this helps.
