Got my rear brakes off and noticed that there's only 1 shim on each side, on the bottom on each. Is this right? I assume there should be 2 on each side but don't want to go and get a fitting kit if it's not needed.
Yeah it's the ones that go on the carrier that I mean. I assume someone has removed one when fitting new pads if they were a tight fit cause its on almost 40k and the pads look new on the back
