Hids can-bus
Buddyboy
I've just ordered the ultimate xenon hid conversion kit H1 35W 5000 can-bus from hids4u can anyone tell me if its the right one as getting a little worried because it says can-bus on it .
Yeah sounds right matey. I put a set on mine last month, miles better. Don't worry about the can bus part, that's what you need, stops any bulb failure warning coming on dash, which happens with cheap hid kits.
Once the bumper is off you'll see a couple of places you can tuck it on each side, not a lot of room though!
I work at a mini dealer! So have checked to be sure, but parked up to my garage and put a line on the door where each light level was, then lined the new lights up to the same line. Simples!
Can't help, but good little tip that is.
