Your driving on the wrong side of the road, but if the car is from your country check the bulbs are fitted correctly it maybe fitted but not sitting just right in the holder the projector headlights have very little room to check you almost have the take the headlight off the car to be absolutely sure.
But if you have the projector headlights check the bulb is aligned with the metal tab and is sitting flush (flat) on the plate
