Afternoon Chaps :wiz:
I'm going to swap the gearbox oil this weekend, primarily because I've got the synchro issue when going into third at high revs. Admittedly the car had this when i bought it and i didn't notice it, it's not really a problem because it doesn't happen often and the gearbox still seems strong/smooth in all gears.
Main reason i'm doing it is preventative maintenance if that's a real thing!
Anyways what oil should i go for!?
Is the standard: Elf Tranself NFJ 75W-80 Gear Oil the best???
