Gear stick won't centralise
Hi guys,
Since I've owned the Meglio, my gear selector won't centralise when out of gear, in an R27 Clio with a 225 box, anybody have any ideas :smile:?
225 box will most likely be the plastic bush in the selector mechanism - you can remove the selector from the box & free it off
been a while since i have done one but its the lever on the right that goes in to the housing at the bottom with the bush in it
Thanks for the reply mate :smile:, relatively simple job? Any guides anywhere ect?
not too bad just have to take out the correct retaining bolt on the side of the box that holds it all in place after removing the top bolts
