Front wheel bearings
Good Morning all,
I need a new wheel bearing for the front of my clio. I don't really know much about bearings. But in my search online for some I've found these and I've also found these.
Does anyone know which one I need? I'm only having the bearing replaced because I need to replace the stub axle as the threads are buggered.
Many thanks
Front wheel bearing can be bought aftermarket.
BRT bearings use genuine SNR bearings which is what renault use.
Other Part Numbers for the bearings are -
BRT - PWK1989
SNR - R15584 P
Firstline - FBK1242
Reactions: Lauzmmj
Thanks for the reply, but that wasn't what I was asking. If you check the links both are genuine Renault but one contains just a bearing and the other contains the bearing with 4 bolts, a driveshaft but and an 'abs plate'.
