Focal 130as speaker fitting
At the very least you'll need to cut / remove two of the fixing tabs on the speakers; and perhaps modify the other two slightly by filing / grinding.
The Clio 'inserts' are a funny shape and nothing seems to fit "exactly" (Damn close - just not quite)
And there's only 2 of them as mentioned !
With a small grinder / dremel etc - its a 5 minute job.
OK cool, have access to a dremel at work so hopefully wont take too much to modify it. Not sure if the depth of the speaker will be an issue, hopefully not. Also not sure if I will need adaptors for fitting them.
Sent from my F8331 using Tapatalk
Only just seen this post. Yes the headunit was changed for an Alpine. The sound is really good, bit of sound deadening and I'm very happy. Amp the speakers I think it would be better still. Very worth the upgrade
