Fitting 4-Point harness help
HarryJT97
Hi Guys,
So I recently got a cage into my RS200, and now wanting to install harnesses. I've looked around a bit on the forum, and I've seen people recommend these: 'https://www.msar.co.uk/harness-fittings/schroth-b23a-harness-clip-kit.html' as mounting point for the lap belts.
So with these installed, do you have to put a spreader plate on the back of the tunnel (Where I'm planning on mounting the harness clip) when installing these? I'm sure you do but I thought that it would be worth asking.
These are the spreader plates I have seen, are these okay to use? https://www.msar.co.uk/harness-fittings/schroth-harness-eye-bolt-back-plates.html
Thanks! First time installing harnesses so any advice would be great.
Thanks.
They’re a good little design them. I just used conventional eye bolts.
You’ll 100% need spreaders though. Mine are mounted through the floor on one side, the the exhaust tunnel on the other. Plenty of room to do as you please.
Reactions: HarryJT97 and Beany
Mines fitted exactly the same with an eye bolt in the exhaust tunnel with a spreader plate.
loads o room
loads o room
Thanks for the replies guys, what length eye bolt did you use? I can see there's lots of different thread lengths with 22, 23, 32, 38 and 50mm available. I assume the standard 22mm length will be okay?
