Finish Kare 1000P Hi-Temp Wax Sealant
aaron-rs197
Thinking of using this on newly refurbished front calipers to seal them and to help make cleaning dust off them easier.
Anyone got experience with this product?
I use FK1000 on the alloys with most details, it has a higher temperature resistance than your typical wax or wheel sealant. A lot of people seal their wheels and calipers, and then when it comes to washing they spray the area with a dedicated wheel cleaner and strip away the protection, the same applies to the calipers. On sealed alloys or calipers you should only require normal car shampoo if cleaned on a regular basis (weekly).
Fk1000 is very good, it needs to be left a while to cure, once it has a dry film you can remove, would recommend 2 layers. Alternatively you could apply a ceramic coating which will last a lot longer and offer a harder more durable barrier, obviously not as cheap though.
