Few questions about Megane parts fitting clio!
Will the Megane manifold fit onto the clio?
Can the clio ecu read boost?- or will the Megane ecu fit on my loom?
Some of you may see where this is heading! Just asking a few questions to see if its possible? Thanks, dan
PM SteC on here. He's done a couple of conversions with a 225 and a 250 engine.
Hi, I wasn't after putting the full engine in, I was wanting to turbo the clio engine. Just wonderd if I could use the magane parts? Turbo, down pipe, manifold, ecu ( if mine cannot be mapped to hold boost) etc
Its been discussed before, the weak link is the bottom end. The way forward is the 182 bottom end with the 197/200 head and bolt a 182 turbo kit on it.
Prob not as simple as that tbf
Conrods aint the best, and if you get away with it, the gearbox wont lastlong. and i think the engine is too higher a compression for a turbo. Plus theres a good chance that the manifolds bolt patterns are different. Best option is megane conversion.
^^^^this, youll hit a brick wall straight away. Much cheaper doing a whole conversion.
fernandez hit the nail on the head, it seems to be a pointless excercise when the meg engine is as cheap as it is
