Fan fuse gets break
manmr94
Hi, my fuse fan (located next to battery) gets break easy, in five months two times, what is the problem?
All you can do is check that the fans spins freely and that there is nothing to jam them like a loom cable or a bolt/plastic that has been dropped into the cowl and that it is fitted securely. You could change the fan relay or the fan resistor on the fan housing.
I noticed too that my fan NEVER runs on high speed (the low speeds works), i dont know if this is related with the main problem and makes that the fuse gets break.
