Exhaust tips ?
I'm looking for tips for my exhaust,
In the search the supplier people were using no long supplies them,
Anyone know where i can get a set that will fit or give the measurements so i can look for a set that will fit..
If it's a Clio 197 then the biggest tips that will fit in the diffuser holes without touching and melting them are 3" if that helps the genuine Renault sport ones are 2.5" and look a little small when you see them from the rear.
Reactions: Shannon larmour
Well the Renault sport is a straight inwardly rolled tube and is 2.5" outside so take a mm or 2 off that would make the internal diameter approx. 60 -61mm the outside diameter then would be approx. 63.5mm.
