elf EVOLUTION 900 SXR 5W-40 vs BAPCO CHARGER XTREEM 5W-40
Hi,
My car is due for oil change, just hit 40,000 KM. I called the local Renault dealer but they don't have elf oil. Since many Clio owners use elf oil but if I don't get it, can I safely use BAPCO CHARGER XTREEM 5W-40? This BAPCO oil is produced by the company I work for. Your feedback will be highly appreciated.
Here are the datasheets for both oils...
attachment.php
International specifications:
ACEA A3/B4API: SN/CF
OEMs approvals: RENAULT RN0710 et RN0700
Test PropertiesMethodUnitsSAE Grade 5W-40
Density at 15°CASTM D1298kg/m3855
Viscosity at 40°CASTM D445mm2 /s90
Viscosity at 100°CASTM D445mm2 /s14.7
Viscosity indexASTM D2270-172
Pour pointASTM D97°C- 42
Flash pointASTM D92°C230
B.N.ASTM D2896mgKOH/g10
Apparent Viscosity by CCS at -30°CASTM D5293mPa-s-
Apparent Viscosity by MRV at -35°CASTM D4684mPa-s-
Noack VolatilityASTM D5800% Volume-
attachment.php
International specifications: ACEA A3/B4 API: SN/CF
OEMs approvals: PORSCHE A-40, VW 502.00 / 505.00, RENAULT RN0710 / RN0700
Density at 15°CASTM D1298kg/m3858
Viscosity at 40°CASTM D445mm2 /s-
Viscosity at 100°CASTM D445mm2 /s14.5
Viscosity indexASTM D2270-170
B.N.ASTM D2896mgKOH/g9.5
Apparent Viscosity by CCS at -30°CASTM D5293mPa-s6,400
Apparent Viscosity by MRV at -35°CASTM D4684mPa-s35,000
Noack VolatilityASTM D5800% Volume11.0
