Eibach Spring help - Its me again XD
CM200
Hey all Ive had someone offer me some used Eibach springs for £40.
The only issue is he says its for the 'standard' facelift. Do they do Eibachs for the regular MK3 ?
If so any chance I could fit them some how or is it a straight up no go? I'm partially torn between these or some more expensive H&R 30mms.
Many thanks for any advice :smiley:
Later cars (MY 10-13) had different top mounts, and hence different diameter springs.
As above the later 200s had different top mount designs so anything after June 2010 will have the smaller top mounts.
there is a period between 2009 & early 2010 when some 200s share the same top mount design as the 197s
So ideally you need to ask your guy which variant before you commit. If in doubt stay away otherwise just wasting money
Cheers Beany I’ll give him an ask!
