littleg78
Hi All,
I bought some 20mm Eibach Pro Spacers for front and back. They're the System 7 type, which means they attach to the hub, then the wheels attach to the spacers. Anyway, they're supplied with bolts that secure the spacer to the hub, and I believe I "should" be able to use my current bolts to secure my wheels to the spacer...
The question is, has anyone on here used these spacers before, and if you did, were different length bolts required for your wheels?
If I need slightly shorter bolts it would be great to know ahead of time so that I can order
If nobodys tried these ones before I'll update the thread with the results when I'm done
