Hi all,
Apologies for the demanding first post. I've recently bought a Clio 200 which is running an EC1 (later edition) ECU. Engine is largely standard apart from a bit of head work. However, I'm having some running issues and finding it very flat indeed. I believe it's a sign that the VVT is not kicking in properly.
I was hoping someone here might have a base map which I might be able to take a look at? I don't plan to run the car on it, but I'm looking at the way the solenoid output is configured in the ECU. From my limited knowledge, I'm pretty sure mine is set wrong.
Tanks in advance if you can help me.
Regards
kev
Regards
kev
