Drivers electric window
hi all, my drivers side electric window does not work on the one touch up or down, it just edges a few centimetres at a time and stops, I’ve tried to reset the window as described elsewhere on the forum but still not working correctly, is this likely to be a faulty regulator?
I get the feeling it may be the switch rather than the regulator, just a hunch though. The one touch drivers window on my car is reliably intermittent, same with the passenger side power-folding mirror.
:french:
:french:
Cheers for the reply bud I’ll take the door card off this weekend and have a look.
..try disconnect the battery for a few minutes, then only try using the passenger unit only, then move onto the drivers side and sometimes it just works. Worth a shot. GL
