Ironically there doesn't' appear to be a specific section for electrical questions on the forum so I'll just put this here!
Ok, so had my Clio a few weeks now and it’s been spot on so far. I have recently noticed a strange electrical phenomenon that I wonder you can help with.
On occasion the light behind my heater control nearest the driver (this one only) is sometimes slightly dimmer than it should be. Other times it’s at full brightness, but when I turn the knob on the centre control for the heat it triggers the reduction in light behind the knob nearest the driver and it stays like that until it randomly decides to go to full brightness again. At first I just figured = French car = sh*te electrics, but recently some other things have been happening: When I start the car in the mornings the radio is on as it should be (as I turn off the car with it still on), so it plays for a little while, then stops (possibly turns off and on again but doesn’t seem to power down just says ‘please wait’ on the digital display up top).
Then on top of this, Monday I got in it after work to drive home, start it up and ‘low battery’ warning popped up (light and indicator). I turned off ignition and on again twice and it cleared the problem. Then next day I went out at lunch and it started ok, but then randomly kangaroo’d and the all the dash lights came on (esp, etc etc.) I pulled over, turned it off and on again and it was ok after that. Reading up on it I suspect it needs a new battery (she is 5 years old) but I am also concerned that it could be related to the alternator as I have read a few other reports of cars with same symptoms.
At the moment it’s been fine and no low battery warnings at all. However the heater light being dim and the radio turning off randomly is still present. What do we reckon? I am aware French cars have gash electrics so fully expected something like this to happen.
