bigsid
I'm halfway through replacing my timing belt/aux belt/water pump and the service manual is telling me to remove the crankshaft sprocket (not the aux belt pulley). I just don't seem to be able to get the bloody thing off. It's got a notch out of the sprocket and the shaft for a woodruff key by the look of it, but it's not externally visible so I can't grab it with some vice grips and wiggle it out. I've put a load of penetrating oil all over the sprocket and even made a makeshift removal tool using some flat bar with holes in to screw M4 bolts into the threaded holes on each side of the sprocket, but it just won't budge. I can't get a screwdriver or prybar round the back of it because it is really pressed up against the crank seal, there's maybe a few microns gap.
Is there a special tool I need or can get to help me with this? Do I really need to remove the crank sprocket or can I get by leaving it in place. Any advice would be much appreciated.
