JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Am I correct that the 581 offset pins in the picture are correct for my 200? And also is it the same pin types for front indicator bulbs as well as back?
Just wana checked before u buy some replacements
Many thanks
Platinum Legend
be careful removing the rear lamps, they are a bitch to get off and you may crack them like I did
Thank s ibe heard there fragile so I'll be careful
are they the offset pins though???
Platinum Legend
