"clonk" sound when lift off throttle cold
Antti O
Gold Member
Okay, my 197 has little clonk when i lift off throttle when engine is cold.
What is your suggestion i first have to look about?
Possibly engine mounts?
Upper left near oil fill cap or lower near gearbox?
I found this from forum:
A hollow knock from the front right at low temperatures is the upper engine mount (also called 'stabilization bar' or something similar).
This is normal, most 197s & 200s have this noise, in most cases it goes away when the engine is warmed up.
If the noise is always there, then replacing said mount will cure the problem.
However, the problem described in this thread is completely different..
Okay, just what i have.
Is that fixed by changing that upper mount?
it could be either top stabliser or the bottom gearbox, or it could be lower arm link. with out physically looking at it underneath it could many things
Can you move it by hand?
I will test it tomorrow or next week because hood is frozen.. have to open it really carefully so dont break anything.
I'll let you know when I replace mine. I'm pretty sure it shouldn't have that much play in it.
