Antti O
Gold Member
Hi!
I have 74000km driven 2006 RS197 which i have had 3 years for now. I really like this car.
It is properly serviced by local renault dealer.
There was been 2 times when i drove car from work to home and i did notice that something strange is happening. It is normal when engine is cold that you dont have power in clio 197.. but today was +1 and i used block engine pre-heater as i do when is cold. Anyway i drove 5km and then tried to accelerate hard. Between 3000-5000 it was some kind of sluggish to rev and intake noise was strange. It did exactly the same some months ago and next day it was completely normal.
I did use universal obd bluetooth reader and there was not any fault codes present. Naturally the CEL light was not on.
Car was idling normal, taking revs. Just lack of power.
Any ideas?
Edit:
I tried it 10min ago and it run fine and sound normally. All power was there.
Is it possible that VVT-gear is broken? I cannot check with fault codes with proper reader today. I only have bluetooth obd universal reader.
Do VVT gear always give fault codes, do F4R engine have some kind of monitoring system for the intake camshaft angle?
Any ideas?
Edit:
