Clio 197 Ultra Red 2007 from Finland - another BMW bought
Discussion in 'Projects/Progress Threads' started by Antti O, Jan 2, 2017.
  1. rSilva
    rSilva Paid Member
    61
    Portugal
    Car:
    Clio F1
    While doing the flexi's job either the trigger cable or the main power cable to the starter might have sustained some damage and now it broke
    PS: First thing I would do would be to get under the car and manually try to make the starter work by connecting the trigger to the main power cable with a bit of wire
  2. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Clio 197 Ultra red 2007
    Yep, you might be in the right track.
    We discussed about this in irc channel this morning, and there was also this idea.
    We will see later, when this specialist have time to check it.
  3. Pav
    Pav Moderator
    11,464
    Manchester
    Car:
    albi blue 197 with boost
    Sorry to hear anti..been there and k is it doesn't feel good to see your car being towed away..hope its sorted soon..
    Antti O likes this.
  4. Dumdum
    Dumdum Gold Member
    705
    near mansfield, notts
    Car:
    Renault Clio RS200 CUP/fiat ducato campervan
    A battery can die in a night, they don’t nescesarily get worse over time...
    Happens frequently in England on colder months
  5. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Yes i know we have -30celsius in wintertime.
    Different symptoms usually it only clicks solenoid or really slow crank when flat battery.
    First thing was jumper cables and power from another car.. no help.
    Dumdum likes this.
  6. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Small update from mechanic
    -Starter works normally
    -Car starts with push start normally
    -Starter switched +12 is missing when you turn key..
    Ignition barrel..?
    French electrics :french:
  7. rSilva
    rSilva Paid Member
    61
    Portugal
    Car:
    Clio F1
    Didn't you had a loose barrel recently? Some wire might have gone bad with all that movement where it shouldn't happen...
  8. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Correct. I told this yesterday for that garage who is trying to fix my car.
    Nothing new so far.. no any solution.
  9. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Tracking completed.
    Not so much to adjust, but little tweaking.
    Now i can be sure that wrong tracking would not eat my michelins.
    Some plans for winter months, car will be in heated garage between october-may:
    - Car detailing wash, + reload product for ceramic coating
    - Wheel well wash
    - Wheel wash inside/outside
    - Brake caliber cleaning / maintenance
    - Car floor mats, seats etc will be washed with fabric washer
    - Right rear door speaker grill tweak (rattling)..
    - Oil change in January 2019 (oil change interval will be something like 1500miles).
    - New coating for windscreen
    This summer has been quite mad for this car. Ultra low usage.
    - only 1 time in rain
    - approx 1000 miles in total 2018..
    - 0 miles in gravel road.
  10. Johnny 99
    Johnny 99 Winner - POTM October 2018 Platinum Member
    2,468
    Inverness
    Car:
    Clio Renaultsport 200
    Hope you get to enjoy the car before October Antti.
  11. rSilva
    rSilva Paid Member
    61
    Portugal
    Car:
    Clio F1
    What happened to be the issue with the ignition?
  12. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    When exhaust manifold was removed/refitted, it dented / moved starter heat shield which is located really close exhaust manifold.
    Heat shield misalingment caused short circuit in starter switched +12v. Fuse blown.
    Now heat shield is in correct position and car works fine.
    Sean197 likes this.
  13. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Wash day:
    Prewash foam: Korrek PP CLEAN
    Shampoo: Korrek Reload TFC shampoo
    Washmitt: Microfibre Madness Incredimitt (this is such a great thing)
    Washmitt2: car pro mitt for wheels
    Drying towel: Autofinesse AquaDeluxe / Elite car care yellow towel for wheels and other not so clean places.
    BLJ and Big Ben like this.
  14. Pav
    Pav Moderator
    11,464
    Manchester
    Car:
  15. -Eddie-
    -Eddie- Missing In Action Paid Member
    2,375
    Belfast
    Car:
    200 Cup
    Sorry to read and see the problems you have had with the car recently Antti. I love reading your thread and admire the dedication you have keeping it 100%.
    On a side note, I’m also a huge fan of the Microfibre Madness range. I opted for the Incredipad XL as I don’t really like mitts. Car looks awesome as per usual :smile:
  16. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Hello again from north.
    This september has been nice for its weather and i dont have any panic to get 197 for my garage. In fact, BMW is kaputt once again.. rear diff seal is leaking lot of oil. I hope it will be fixed soon. I have all parts in stock, but my friend will fix it when he have time for it.
    Clio 197 will be tracked once again, because steering is not in center.
    Johnny 99 likes this.
  17. Pav
    Pav Moderator
    11,464
    Manchester
    Car:
  18. adam thomas
    adam thomas Gold Member
    257
    Birmingham
    Car:
    Clio 197
    just sat and read this entire thread , can't get over how clean this car Is ! I think I need to up my detailing and get somewhat close to how clean this is !
    awesome work !!!!
    BLJ likes this.
  19. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Hi, thanks!
    It takes a lot of work to first do paintwork correction, coatings and then try to keep it in perfect state..
    adam thomas likes this.
  20. Antti O
    Antti O Gold Member
    1,472
    Mikkeli, Finland
    Car:
    Now i will tell you story how to make stupid mistake in car washing and what will be result. :neutral:
    Previous week our primary parking area in my work was reserved for other use.
    Because of that, clio was near large spruce trees.
    I thought that only trees which have leafs can coat car with tree sap or aphid waste.
    I WAS WRONG..
    There was storm and rain all over week when i was work. Car was covered with all kind of stuff from trees.
    Friday when i did my weekly wash, i saw that car paint was covered with tree sap or something which was more like wet/sand paper feel than absolut smooth and flat clearcoat. :frowning:
    I was tired about my week at work, and i washed car with normal mitt and after that i took my clay mitt from garage.
    I soaked it in shampoo and it was easy to use and all tree sap gone after 2-3 passes over roof for example.
    Clay mitt
    I thought, okay that did the job.
    In the evening i parked car in my open garage which has good led lights.
    When i saw car left side (this part was repainted 2017 may). It has swirls all over from back to front.. NOOO
    Maybe i did not had enough shampoo between paintwork and clay mitt.
    I completed many washes for this car and never caused swirls, i have top equipment for washing. Also summer drive only preservers paintwork.
    Only solution for me is to fix swirls and do ceramic coating again. In that level i want, there is just 1 man who can do this. It will be same guy who did it 1 year ago.
    Car is now under work and i hope it will ready in sunday. There will be same ceramic coating re-applied because machine polishing will take old coating off.
    You have to VERY CAREFUL with clay mitt / claybars..
    I have done many car contamination cleans with this same clay mitt (BMW for example), and never caused this bad swirls. I dont know is the problem that clio left side which was repainted laqcuer is soft.
    Sean197 likes this.
  • Share This Page
