Clio 197 Tracking
Hi everyone, Had my 197 in today for new front tyres and tracking... Turns out the tracking did need doing, but was told the rear was fine.
Just curious as to why one rear has more camber than the other and if it's something to worry about?
Thanks in advance.
Wow, that is shocking. Nearly neg 1 degree difference in the rear. Did you not question this at the time? The Left rear didn't change in Camber from before & after figures.
Rear is not adjustable unless shims are used. In other words it came out the factory worth a full degree difference. Both my clios had the same problem
