Clio 197 ~ How to remove the rear plastic interior?
Hello all,
So I've been fiddling with my 2006 Clio RS 197 and one thing I'm looking at is trying to get the rear interior quarter panels off.
For now I've removed the rear seats so have good access to the panel itself, ....I've given it a good tug and some pop clips have come out so it's partly free but feels firmly held near the B pillar.
How do you get it off please?
Do you have to remove other parts before it will come off?
Any help appreciated. Thanks.
You’ll have to remove the speaker cover and i’m pretty sure there’s 2 screws behind there.
There’s also another screw behind the white bit of trim in the top left of that picture
Fairly sure it should just pop off after that
Reactions: GMballistic
Thanks @EthanMenace .
I'd removed the rear speakers and the two screws holding them in already. The other screw behind the white bit is there but doesn't hold the piece of rear trim I'm removing so I gave it a bit more of a harder tug.
It did come away then and the only other thing I had to do then was remove this weird rubber strap thing.
Hopefully the pics help others who may wish to remove this. To take it off completely you would also have to remove the lower seat belt runner rail but that's an easy job.
Reactions: EthanMenace
