Anyone happen to have a Clio 197 fuel pump/unit laying around?
I'm interested in the numbers on the black connector block.
Just checked a 1.4 pump and that seems to be a 95lp/h pump which isn't too bad, pressure regulator says 350kpa.
I'm trying to find out when/if the clio pump becomes a problem with a 225/250 conversion.
What i did find out is it has a 0,3l swirlpot inbuilt with another 0,27L of pressureless reservoir when the pump runs dry due to cornering. So let's say there's about 0,2 liter to burn when the pump runs dry, this would mean one could run 4x480cc injectors flat out for one minute.
So does the Clio/Megane need a swirl pot? No, imo not....
