CallorFold
Clio 197 - 2008 with under 60K on the clock -
What are the chances of an issue presenting itself with the Gearbox if it's been ok for the first 60K? Should I expect to have to replace this within the next 10-20K miles etc?
The car seems to drive OK at the moment, no noticeable crunches between gears. I plan to change the Gearbox oil to Redline MTL 75w-80 GL4 as per the recommendations from the Gearbox failure thread.
Is there any "test" I can do to check the gearbox - shifting from 5th to 3rd etc.? Shifting between gears at specific RPM?
Presumably it's a fairly obvious crunching sound when there's an issue?
