Bulb problems
I'm wanting to put bulb upgrade in my 200 cup, I was wondering what the best way to go about it is ? Looks a pig of a job !
it is a bit of a pain, i did mine the other day, basically on the drivers side you unbolt the pressure switch on the slam panel, remove the battery box lid and fuse box lid, unbolt the air feed and puch it out the way, you should now just about be able to fit your hand in to the back of the lights.
passenger side is alot easier, pull off the filler kneck to the washer bottle and you can then easily get to the back of the lights
