Brembo Caliper seals
PAUL JA
Hi
Can anyone confirm the part No's of the genuine Brembo piston & dust seals ? I know I've seen a picture of the brembo boxes with the part numbers showing but can I find it !!!!!
Also
Has anyone experience of using the kits supplied by Budweg or Bigred ? I'm assuming these are cheaper than the genuine Brembo but do they perform?
I too used the Budweg ones, perfectly fine. It's just a piece of rubber after all.
I made a guide of the strip and rebuild of the Brembo's, it's somewhere in the guide section if you need it.
Thanks for the replies chaps
Has anyone come a cross a high temperature seal kit ?
The dust seals look pretty cooked !!!
Are they all wrinkled? Mine were the same. I think I came to the conclusion that it was brake cleaner or some alloy wheel cleaner that did that to mine
