brake fluid and abs
Foxspeed
"the new red baron"
Moderator
ABS unit
black pipe to rear feeds fluid to clutch master cylinder
Does the clutch require bleeding when you change the brake fluid then?
nope should be fine - as if you let the reservoiur get that low to the clutch inlet pipe you will drag air in to the brake system as well
