Braided Brake Lines
Hi guys,
Where is the best place to purchase a set of 197 front braided brake lines?
I had some previously but they were too long and causing a knocking noise against the arch liner.
Thanks.
hel only have one grommet per line and you ideally need two.
not fitted them on the clio so can't comment on length
They did two different types at one points, one with a single grommet another with two. I just checked my order history and I ordered HEL twice.
OP just make 100% sure they are fitted using the OEM brake hose bracket that sits on the hub otherwise you'll have a bad time.
Hel used to only have one. They should now have two. The ones I received from Camskill only had one so I emailed Hel and they sent out another couple of grommets. According to Hel everybody has been told they should have two grommets.
Mine came with one for the meg, the tech just fitted some tubing over instead.
