Bleeding an empty system on 197 advice
Andyyox
Snapped a bleed nipple off in my brembo but it must have loosened a bit first a and I didn't realise so lost a load of fluid
Read somewhere that this will cause a problem for the abs module and it might need plugging into clip and setting to bleed ?
Is this true ?
Taking it as an opportunity to refurb calipers and fit braided hoses so need the best way to bleed them !
Andy
Only one way to find out. Fill the reservoir and open the bleed nipples and let gravity do the hard work for you
