Hi guys, new to the forum and just got myself a 197cup, its had a centre box and 2nd cat removed as it says on an invoice it has, there seems to be a very bad flat spot between around 1500 up till 3000k where it just splutters and rattles and something sounds like its moving or loose underneath. But after 3k it seems fine and feels normal with and nice little bit of pull to it.
To be honest i hate the way it sounds overall, very raspy just sounds ridiculous. The car has apparently just had the manifold welded as it had cracked, but it does sound like the exhaust is hitting off something maybe the welding has caused it to hit of the subframe?
So is this flat spot something that usually happens with the bits removed that 'mine has? And does it sound like something that could be mapped out?
And also im not sure if the invoice for the centre box removal and "2nd cat" removal actually means the normal cat or the pre cat as all thats written is 2nd cat so a bit confusing.
Here's a pic of her anyway, just got out of an r26 and into this [emoji23]
