Anyone know where the OBD2 Connecter can be found
Under the key card slot, there is a plastic cover that you need to remove to access it.
I had a Scangauge plugged into mine all the time, and now leave the Garmin Ecoroute HD plugged in all the time.
I did/do, it was useful for its limited data logging capability. Had it plumbed into the Puma for use as a fuel computer, but obviously the Clio has one already, part of the reason I swapped to the Garmin - that doesn't log data, but does display much of the current info shown on the Scangauge.
