Anti roll bar bushes
How hard are these to change?
Replaced these on previous vehicles and they were straightforward, anything 'special' about the 197?
this !
very tricky to get too - if you look over the top of the engine/gearbox and look down you can just see them :mellow:
Cheers, had a look underneath on Saturday morning briefly and couldn't see hide nor tail of them. Damn Renault
Yes bit of an arse to do. You'd have to drop the subframe which isn't too bad but I can't see it being worth it for the effort.
Where are you in the Northwest? I've dropped mine a few times and dropped friends too fitting manifolds and anti roll bar bushes. [MENTION=52200]montana[/MENTION]
I'm just at Haydock. [MENTION=52200]montana[/MENTION]
Wheels off
Undo drop links
Undo the lower engine mount
Undo the two bolts from below which hold the power steering pump in positon.
Dropping the sub frame which is held up by 6 bolts, 4 are the rear and two tucked higher up at the front behind the wheel arch trim.
Drop the subframe onto your chest or jack.
Undo the Anti roll bar bolts
Wrestle out the ARB
Refit.
Give us a shout if you need anymore.
