Alignement values with h&r
Hi there,
What do you think guys... If the car with h&r got the same height as a 220 Trophy, could it be possible to set the stock values from 220 to the 200t?
I'm having some difficulties to get a good set up with the car lowered...
Enviado desde mi HTC 10 mediante Tapatalk
your only adjustment is front toe, if you want agile / turn in go for a little toe out - maybe 1mm total
the rear you will have to shim to correct or change
all depends on how much time / money you wish to put into it
get it on an alignment rig and see where you are starting from
Reactions: p4l0m0
